Composite Device?
Just received an RS90 yesterday, and I’m trying to get it set up. My living room has three devices: An LG TV, which provides the video, a Yamaha receiver, which provides the audio, and an Apple TV, which provides the content. I have all three devices added into a room and I can control them all individually. What I want, though, is a setup where the volume buttons control the receiver, the navigation buttons control the Apple TV, and the power button uses a macro/sequence to turn everything on or off. Is this possible? I cannot figure it out in the app and the online quick start guide is similarly not helpful.
If you create a sequence and add all the devices that should be controlled within it, you can assign commands of individual devices to specific buttons under “Key Map” in the sequence. As soon as this sequence is activated on the RS90, the defined key mapping will apply.
Check out this walkthrough once.
