Logitech Harmony
Why don’t you look at the (old) Logitech Harmony to get thnigs working like it should be working if you want to have a great compatible remote controle. My RS90 isn’t working like I expected to work. Ziggo box (or Cisco) isn’t working wel (you can’t change the channels up or down). My Samsung television is working but IR signal is weak (you really have to point the RS90 in the right direction). And you can’t make a macro like the (old) Logitech Harmony. As example: when I push the green button on my Harmony my settopbox (Ziggo) goes to the menu then goes to the apps and then selects Netflix. When I push the off button everything goes back and goes off. Why can’t you copy those great features from a remote that worked great for many many years.
Now I still use my (old) Harmony because the RX90 (without extender) isn’t doing what I thought it would do. It looks great but isn’t working near as good as my old Harmony.
Let the IR hub arrive before extender. It will cover all the missing functions ( mostly IR)
Logitech has two part system one is Remote and the other is Hub.
We only have remote ATM. Let the system grow. We exactly know how to achieve that level of user friendliness.
