Working towards Handling Power button
Hello everyone, This week we are working towards introducing macro power button features. With this feature coming up under macros, each macro will have power button choices to make:
  • You continue using key mapping.
  • You can use the same button to turn off the whole macro (do nothing).
  • You can hold to turn off everything, which means all of the running macros will shut down (total power off).
This is something very important we have been waiting to implement, but now it’s time for us to consider it, as the macros are now well implemented.
live now in the 4.2.
My extender can no longer be connected to the RS90 any idea what that could be ?!
There is now an extender setting check there in remote.
