ADB not working
Hello,
It seems that there is an issue with android TV 14 and random ADB port.
My android TV is well discovered in the configuration but when i want to control it with the remote, an error message appear “network problem”
How could we do to connect to an android TV 14 ?
Discovery is done via mDNS but to communicate with Android TV we need access enabled from the TV settings. Make sure ADB is enabled on the TV. Usually that is only visible under developer settings. But you can share some photos of the TV settings page here.
Hello,
ADB is enable. The problem is that the port is not 5555 since AndroidTV14 and that makes an issue.
I used this sub https://www.reddit.com/r/AndroidTV/comments/1pxv69g/working_fix_chromecast_android_14_adb_port_5555/?tl=fr to force ADB port to 5555.
It worked the first time but now it’s not working…
Ok, we will check this. Thanks for sharing.
