Any support for Vizio TV's other than Infrared?
Wondering if anybody’s had luck getting Vizio TV’s setup with RS90. Mine has the proprietary Vizio interface, not Google TV, model is V756-J03. Very spotty with infrared and the RS90 so hoping for another option but haven’t gotten any to work. Thanks.
Which OS is it? if you can tell us.
Looks like it’s “SmartCast”. V756-J03
I think it’d work ok via infrared but suffering from same on/off problem in sequences like I posted about before.
Thanks
Thanks for sharing. This OS can be controlled via a python program so we can implement it. Just require some more weeks to be able to get a Tv with this OS and test.
