Hi all,
I have been using the rs90 exclusively using home assistant on the fully browser with mqtt and it has been working well. One of the small problems I’ve noticed is that the centre button short press does not send an mqtt signal, only a long press seems to work.
I tried using button mapper to fix it but it seems to need connecting with ADP so it’ll have to be a weekend job.
Is the lack of short press response a feature or a bug? ![]()
