Hey guys hust wondering if we could get Govee to be added to Haptique remote
Can we possibly make adding thinks a bit easier for example Samsung Tvs and Samsung Soundbar setup is quite confusing
Govee we are using in our setup in IFTTT.
Samsung Tizen IP integration is coming later as we have created the project( a dedicated app) but needs implementation on the current system app and config app.
Soundbar should work with Infrared and so it the TV.
Hey so to be clear Govee Support is being added also amazon devices would be awesome ![]()
So will Govee be added? I do not see a response validating it will be added or has already been added.
For this first we need to understand the usual customer setup.
Can you explain your Govee setup? Do you have all Wi-Fi devices? I am asking this because we have Govee bulbs but are Bluetooth only.
Is your setup like Hue? where we currently handle Hue Scene, groups, and devices. Do you expect the same method with Govee?
The more we learn, the faster we will evaluate this integration and send it for development.
The current easiest way is to use Home Assistant as a middleman.
All my devices are WiFi.
While I do not have Hue, based on your description, it sounds the same.
What is home assistant?
Home assistant is an open sourced, smart home platform which is free to use, we support this as Smart Hub and you can handle most of the smart devices via this Hub in Haptique.
