Haptique RS90 System Update | V3.4
We’re taking the Haptique RS90 to a whole new level of personalization. This update bridges the gap between your favorite Android applications and multimedia control, making the RS90 the only remote on the market that seamlessly integrates custom keymapping across different Android apps.
Custom UI
New Features & Enhancements
  • Custom UI Android Integration: Users can now launch Android applications directly from the Custom UI (Macros) interface.
  • Persistent Keymapping: Support added for continued use of custom Keymapping on Android apps launched via the Custom UI.
  • TV App Integration: Added the ability to place TV-specific applications directly into the Custom UI layout.
  • Macro Execution within Custom UI: Enabled the ability to run Macro sequences (e.g., lighting “On/Off” sequences or other multi-step automation) directly from the Custom UI screen.
That’s nice, keep it up :+1:
Long needed update. At last, the remote becomes usable…
