How to watch Netflix (sequence)
I want to make a sequence to make my (Samsung) television goes on and my Ziggo Mediabox and then when that’s done it goes to the Ziggo box menu and goes to the Netflix app on the Ziggo box and starts it up.
With my old Logitech universal remote I could make a sequence in which I ‘told’ the remote to move the cursor in the menu six steps to the right and then activate ‘enter’. In the app list Netflix was six steps to the right.
Is something like this possible with Haptique? So that I can pusch a sequence button and see Netflix (or app channels like this).
If there was an API to launch the app it would be simple to create an http url under custom URL but Ziggo has no control API like Roku or Android as per my search.
Current sequence doesn’t support repeat of command, we will add this to next update so you can also do 6 presses in sequence.
