When will the IR extender be delivered?
My TV box (Ziggo) is standig behind a small door from a cupboard.
The RS90 needs the extender to get the signal inside.
It will take time for the Extenders to be available, but before that Broadlink integration will go live. Also the third party hub will be available.
Is it possible to use the Harmony hub as an extender with the rs90?
It isn’t working at this moment. I tried at my home.
I have the harmony app on the rs90 and it works with the hub. Unfortunately not optimal but if you could use it as an extender that would be great.
Just use Harmony app or use home
assistant as a bridge to use with RS90.
How do I use the Harmony app as a bridge?
I would be interested in that too.
Found out that you have to install the Harmony app on your RS90. It works fine for now. But in the end I’ll hope that the RS90 will work like a good universal remote.
Home Assistant can be used as a bridge to make Harmony hub and Haptique talk.
You can handle Harmony activities and devices in HA and Haptique will import those entities. We will make a short video by this weekend and post.
I don’t use Home Assistant. For me, everything runs via IR. I would just need an extension of the IR range. Good to know that it is in the works.![]()
Is it possible to add an external application (for example, Logitech Harmony) to the start screen, in the same way you would add a macro or a room?
Need more info, you mean want to launch an Android app? with Macro?
