IR Extender - When?
Do you have an estimated time when this will be available to purchase?
Hello
I’d be interested too. Without an IR extender, the remote control is very limited.
Agreed- IR strength on actual remote is poor.
We are working on to address the reading function of Infrared codes. First will be the web-portal where user will be able to add Raw Hex formated data and Test IR files live with Haptique. Second will be an accessory which will have IR reader on it. We are working on the solution which can even extend the Infrared range over Wi-Fi. Next week there will be an annoucement on both the points.
