There is a new update for the IR+RF Hub, we suggest to test it on your hub to check the stability. We have internally tested it, if you want to help us verify the bug fix do the manual flash and let us know if the Hub is working for you.
This new version improves the device stability over network and random reset problem due to continuous IR commands.
Install Version 1.2.2 and lets us know if the hub is working well for you so we can release it over the new update on config app and upcoming web app.
