Hi @ccsfounder, I thought i’d break out this idea from my other thread, as that’s gone in a different direction.
Would the RS90, in theory, be able to work with a small IR receiver over USB-C?
This could give the RS90 an epic FlipperZero-like ability to clone any remote’s button presses.
No need to even use the companion app.
It wouldn’t need to hit your servers at all, as it’s just local storage to save the RAW data down.
Just as an example, here’s my use-case – which while the inputs will differ, I imagine would mirror a large amount of existing/future users:
Set a nice touchscreen bunch of icons for my inputs on my Amp:
– Switch 2
– PS5 Pro
– Xbox Series X
– Dreamcast (Still waiting for SEGA to release a new one here! ^_^)
– UHD-4K Player
– HD-DVD/LD/VHS/BETAMAX (on it’s own switcher)
– AUX
– Apple TV -
Set core up/down/left/right OK, back etc buttons for Apple TV
Set power button and others to my Amp
Back to the idea/ask above… what do you think?
