I made a macro to start my Dune media player and the Samsung TV. The strange thing is that when I want to use this macro after a while, nothing happens. When I then use the button for the start of the Dune in the macro, it turns on properly. Closing then goes well. If I start the macro again, the Dune turns on properly. It seems like if I don’t use the remote control for a while the connection is gone so the macro doesn’t do what it’s supposed to do.
I use the Dune and TV via ip (not ir)
Does somebody knows how I can fix this?
