Using the Testflight version to add an Nvidia Shield as an Android TV. I have selected the Fire OS/NVIDIA SHIELD option under Select TV. I can map all keys but there isn’t one listed for the Menu key, or for the Mic key. Can I add them? If so, how? Thanks.
Do we have to update the Haptique Config app manually somehow for this update to show up on iOS? The only Smart TV integration I’m seeing is for Android TV? Am I somehow missing it, or do I need to run an update somewho?
Due to the weekend iOS app did not get approval to be available as update from the app store. You can use the testflight app until it gets approved.(12 hours max)
Same Testflight app will be available as update tomorrow.
Should we be able to download the latest config app by now? My iPhone 15 Pro still hasn’t presented me with the newest version. I noticed the release notes still only mention last month’s updates.
Submitted on last Friday, iOS app did not get the approval and got rejected for stupid reason(Using Android word in the text box). We have resubmitted it and should be live today.
