Quick Buttons for sequences - how?
Short version:
What kind of “things” should appear as Quick Button options for a sequence? I only see one of many devices.
Long version:
Currently all my devices in the Haptique app are Home Assistant devices (or automations) or Custom-URL devices.
I have a sequence added to the Haptique app. Then I added the sequence to a room, to one of the many buttons (added as “Macro”, not as “Device”). Now I want to add Quick Buttons, but in the “list” of available things to add as a Quick Button, I only see one of my many Home Assistant automations.
I wonder why this is.
If I understand you correctly, you are looking for this…
Hold your finger on the device for about 1 second
Then the top quick button appears
Yes, then I tap the “+ Schnelltaste” (“+ Quick Button”), but only one command is presented to me as a possible Quick Button.
I think I found out, which command(s) this is: It is the command(s) that is/are in the sequences “ON” part, which is only one in my sequence.
If that is really the case, please somebody fix this. I just want to call any command from any device in the Quick Button.
OK we will test this tomorrow.
Andy news about this topic?
Currently if you use Sequence and want to map Quickbuttons, it only shows commands which are used in that sequence as well as the whole device if you want to control it as full.
