Hi community, please support.
I’ve connected the nvidia shield pro as my streaming device via smart tv and ip. Works well (except no button for the settings, the three lines on the original shield remote, when you have a solution, happy to hear that too), but I have no control of shield when I start the macro, I need to go on rs90 into my room, then long press on device shield, then it says it’s connected successful, then going back and I can control the shield.
After some hours of streaming, it seems that RS90 lost connection to shield, I need to go again via rooms to the deceive shield, long press the icon, connection again established, and I can control again the shield.
What do I wrong?
Thanks so much guys.
Andreas
