I have added my Tv Sony Bravia KD65XH9505BAEP using “Android TV” device. The Tv was listed and added to the App successfully and I added it to a room : OK
But, i tried to “open” it on the remote I have the error message : “There is a network issue. Please check your TV connection and IP address. Try again/Go back”.
I have verified the Wifi connection on TV and the IP. IPs are the same on TV and in the App. Options on TV to allow external device to control are enabled.
Any idea ? I tried to added with IR and the model “3332” fit with my TV but I can’t use it because there is not command to set the input directly on HDMI2 for example (only an “input” that just open the input selection) si it can not be used with sequences… There is no “HDMI2” (for example) on the orignal TV remote but it is possible to do it with IR because my Logitech Harmony allows it by default (but I have no “IR” learner… It is a different topic (probably I will open it on the IR category soon).
Thanks for your help (sorry for my English, I’m French…)
Nicolas
