Figuring out which codes to use -- LG TV
I’m trying to figure out how to program the remote to work with an LG TV model OLED65G4SUB. Which code would that be? The codes are totally opaque, so I can’t tell which one I’m supposed to select. Thanks.
Submit photo of your remote controller , we may find a matching file.
Locating correct Infrared file in the Database
A post was merged into an existing topic: Locating correct Infrared file in the Database
Hello
On my LG OLED83c2, the two codes
LG-11315 and LG-2397 work.
