I was excited that IP support now exists for LG WebOS and thought maybe that would allow me to get the remote working, but it’s still not working.
I went to Device Pool and selected Smart TV. It found my LG TV, which was a good start. It asks me to “Select TV”. There are a few options, none of which say LG, but one says WebOS, so I assume that’s the one and select it. It adds the device. Seemingly, so far so good.
I also add my Apple TV and Sonos without issue.
Then I try to create a Watch TV sequence. That’s where things go wrong. It asks me to
Select the Source device. I’m not really sure what that means, but I pick LG TV. Then it asks for input selection. The screen is blank, however. There are no options to select. I’m not sure what’s going on, but I press Next. Nothing happens. I have to press next 2 more times before it finally moves on. It then asks me to select the device to change channels. Again, there are no options to select. I press next and it asks about volume. Again, no options to select. I press next again and it then asks me to tap done to complete the sequence. I do so.
Now I have a watch TV sequence, but it doesn’t do anything. It doesn’t control the TV, it doesn’t turn on the TV, it doesn’t navigate, change channels, volume or anything. It’s just as much of a dead brick as it’s been the last couple of months since I received it.
Any idea what’s going on and why it’s still not working? Is the WebOS functionality not actually functional?
