Sky Stream and Nvidia Shield not working
Hi,
I have just received my new RS90. As many I was a long term user of the Harmony remotes and was disappointed when they stopped making them.
I’m very excited about the RS90 and my initial thoughts on opening it are that it’s a very nice form factor and really looks the part.
Unfortunately my initial enthusiasm is waning somewhat.
I have Sky Stream in the UK as well as a Shield TV and none of the codes will work in any way. I’m hoping this is just a development issue but until such time as I can get working codes I’ve actually added one more remote to my huge collection rather than reducing them!
Apple TV, Hue lights and my LG tv and Denon amp all work as expected but without the ability to control my Sky box this is not going to get used.
I would love to hear from any UK customers that have had better success
Thanks in advance
There are some files under IR > Sky which works. You should check the Topic Locating correct Infrared file in the Database.
In addition you can use Smart TV or ADB integration to control Nvidia Shield.
